K&N oil filter
#32
Originally Posted by marton
Every time I have looked under a MAF there is a big pool of engine oil lying in the intake under it; so what difference will a few drops of air filter oil make?
#34
Administrator - "Tyson"
On three daily driven 928's with K&N filters I found a nice debris pile on the MAF screen.
I've never seen this with the stock paper filter on dozens of 928's. No matter how old the filter is.
#35
K&N air filters have been known to lay in wait for 15 or 20 years just to instill a false sence of security in the 928 owner. They will then launch their diabolical master plan and spew hatred all over your MAF. Next thing you know, BOOM, and in a quick 20 years you're replacing a perfectly good MAF. I, personally, sell all my 928's after 14 years just to avoid this insidious scheme.
#36
A load of oil on the hot wire from an over enthusiastically re-oil K&N will be too much for the burn off cycle to get rid of.
You may be able to get rid of the excess with a solvent cleaner.
Certainly an excess of oil on the wire will upset the calibration.
I do get some VERY oily MAFs in here for rebuild, but I suspect most of these are from badly oil burning motors, rather than over -oil K&N.
The main cause of MAF "failure" is the normal erosion of the wire, due to the burn off cycle.
I don't recommend K&N because
they don't give more power
they may not filter as well as the stock paper type
over oiling after cleaning is a possibility.
