Climate Control Sliders
The sliders on my climate control are all wobbly. Can these be easily replaced, or are they simply not seated right? Don't want to just try pushing them in and have them break.
The control sliders have two plastic support prongs on either side. They often break.
They also fit into metal brakets for support witch also fall off when the plastic prongs break. Hence the wobbly sliders. The metal brackets and plastic contol sliders are available at 928 Specialist. Good Luck |
They also fit into metal brakets for support witch also fall off when the plastic prongs break. Hence the wobbly sliders. The metal brackets and plastic contol sliders are available at 928 Specialist. Good Luck edit - is this the whole thing? http://www.mailordercentral.com/928i...574%20498%20KT |
Chris,
unfortunetly the unit does have to come out and be split apart to do it right. The fiber optics need to be inserted into the back of the new sliders. Now would be a good time to order the Jaeger led light for the climate control system. Good Luck Rich |
Chris,
unfortunetly the unit does have to come out and be split apart to do it right. The fiber optics need to be inserted into the back of the new sliders. Now would be a good time to order the Jaeger led light for the climate control system. Good Luck Rich Got it, I've seen the instructions, don't think it's too hard. It's going on the to-do list. Thanks! |
Originally Posted by fabric
... I've seen the instructions,.....
Originally Posted by MGW-Fla
Please share??
https://rennlist.com/forums/showpost...86&postcount=6 I've seen it elsewhere I'm sure on Nichol's page. |
