928 Forum 1978-1995
Sponsored by: 928 Specialists
Horn contact ring
Old May 11, 2007 | 04:16 PM
Champagne's Avatar
Champagne
Former Vendor
Default Horn contact ring
Hey guys,
what should I use to lubricate a new brass horn contact ring on a pre-airbag steering wheel?
Thanks in advance
Paul
Old May 11, 2007 | 05:12 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
Purple wheel bearing grease like you would put in boat trailer axles. A thin coat'l do ya.
Old May 11, 2007 | 05:31 PM
AO's Avatar
AO
Supercharged
Dielectric grease?
Old May 11, 2007 | 09:15 PM
M. Requin's Avatar
M. Requin
Nothing at all, if you drive it frequently. Brass on brass in this sort of application needs no lube. Lube will actually attract crud and cause problems. Assemble clean, and don't worry.
Old May 11, 2007 | 09:25 PM
Champagne's Avatar
Champagne
Former Vendor
Thanks guys,
Paul
Old May 11, 2007 | 09:42 PM
docmirror's Avatar
docmirror
The grease is not intended as a lubricant in this case.
