Annual Oil Change? That's BS isn't it?
Originally Posted by M. Requin
..............(although only the little JD garden tractor and a JD 935 diesel front deck mower get laid up for the "winter" here in VA).
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
You guys aren't going to believe this (and I'm not sure I do either) but I had a neighbor in Virginia who would swear on a Bible that he didn't "believe in changing oil...just a plot by oil companies, etc." He claimed he had 112K miles on his Buick. Lot of highway miles, but still....
Maybe he was jerking me around.
When oil gets "dirty" I can actually see contaminents, clouds caused by water, etc. But if it still looks pristine, I'm not yet convinced that it needs changing. Installing clean oil for over the winter while the car is sitting does make some sense...if the contaminents are really that bad, but it shouldn't have to be changed in the Spring.
I once bought a 1929 A-model Ford pickup truck that had not been run in 14 years....and the oil was dirty and I pulled the pan to clean it and it was pristine inside. I ran the heck out of that engine trying to blow it up to justify putting a V8 in it. It would never blow....but the axles, trans, or tires would give...but not it that order.
BTW, did you know that you could use a fresh pork skin for a front and rear mail oil seal in an A-model? Lasts until you can get to town anyway. Hasn't technology come a long ways? i got the A-model up to 85mph once...down hill.
Harvey
Harvey
Originally Posted by Shark Attack
the 85 owners manual states to changes the ENGINE oil every 15000 or 12 months... yes fifteen thousand.
Cottage Industry Sponsor
Basic Sponsor
I change mine very year - maybe - if I remember to do it.
If I forget and it is 2 years I do not worry. I would probably change it after 20k miles just because I can.
Most Europeans - me included - laugh at Americans who have been brain washed by marketing people to change there oil every 3K.
If my car was sitting for 6 months I would definitly change it every year.
Why because I can.
To many "old wives tales".
Why because I can.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
this brings up some experiance.
I had a 87 vett. I never changed the oil. I put 80,000 miles on the car and beat the snot out of it. Not one internal failure. total miles on the car was 122,000. I changed as i went. I would wait for it to be down over a qt then put a full qt in.
Then bought my first new car. a 6 cyl mitsubishi galant. changed oil every 3000 like clock work. engine failed at 80K, main bearing
Holy Moly! I change my oil every 3-5000, which is about every 2-3 months. Mine is a daily driver, although I don't put a lot of miles on it day-to-day. Other than cost, I absolutely don't believe there is a downside to oil changes of that frequency.
Originally Posted by Nicole
Many of the newer European cars now have recommended oil change intervals of 30k kms - about 20k miles. With modern oils there is no good reason to change more often, and in Europe, Oil is more than twice as expensive as here. Yet, they don't have gazillions of engine failures there...
Oops! I just saw Checkmate's post...forget what I said.
Harvey
H2
Seriously, just think if everyone changed there oil every 6-12 months, the oil companies would become trazillionaires!!!
It sounds like too many people are over-maintaining there Pcars. It just sounds like a lot of wasted $$$, time and resources too me. If the manual back in 79 says I can atleast go 8000 miles on Dino oil, what's changed?? CLUE: marketing...
