Using power bleeder
My leak is somewhere in the reservoir/MC/booster area but fluid level is fine so I don't think I'm losing fluid from the MC back into the booster. Too dark now but first thing tomorrow I'll put some soapy solution on the MC bleeder and see if that's the problem.
Wondering if meantime I can still use the power bleeder by having someone (my wife can be very understanding) keep it pumped up while I open and close the bleeders? Will experiment tomorrow to see how hard you have to pump to maintain it at say 10psi.
Thanks for all your suggestions.
Will take a look at the original reservoir cap tomorrow and see if the grommet pops out easily. Would be great if that's where I'm losing pressure but there is that ominous hissing noise which I'm sure is from vicinity of the MC. If an MC seal has gone bad, would that show up as a pressure loss? I think I read another post here saying the pressure is same on both sides of the seal when you use a pressure bleeder.
Went to check power bleeder cap this morning - no gasket. Wait a minute, at the bottom of the box is a short tube for collecting fluid at the bleeder, and that rubber ring round it which I had assumed was just a kind of clip to secure the tube on the nipple turns out to be the gasket that should have been in the cap!
Popped it in, pumped up, no leaks!
Just waiting for rain to stop so I can do the bleed now.
Many thanks for pointing me in right direction. I don't think it would ever have occurred to me without your suggestion Hacker-Pschorr.
Did off-side rear first, then sequence to fronts. Tipped the bottle on it's side when done, MC sought it's own level, i.e. no overfill. S L O W L Y opened the bottle, depressurized & dumped the excess fluid (took about 10-12oz).
When I first opened the bleeder valves, fluid looked like coca cola. I let it run until nice and clear. Now have a much better pedal - high & hard.
BTW, to simplify the process take an empty, clear 12oz plastic drink container & drill a 1/4" hole in the cap. Place a few old bolts or small rocks in the bottle for weight/stability. Then take approx. 2 feet of 1/4" silicone tubing (surgical supply house has it or try usplastic.com) and fit through the hole you just drilled, to an inch off the bottom. Now take another 2 feet of soft wire and wrap one end around the bottle neck, bend it up and place the other end in the open side of the tubing to hold it up/vertical. this keeps it from dragging on the ground and the wire can be bent around any portion of the caliper/wheel stud/backing plate to keep the bottle in place.
The silicone tubing stretches over the bleed nipple nicely, no leakage. Clear bottle lets you see the fluid color & any bubbles. Wire keeps everything in place. When you are done, just pinch the tubing, tighten the bleed valve, and pull the tubing off, hold it vertical to drain any excess into the bottle & place the wire back into it. Voila! No drips, no leaks, no messy brake fluid on the floor.
Have fun.
Hawkeyes
Have fun.
Hawkeyes
Nice tip on the collecting bottle Hawkeyes - thanks.
When you tipped the bleeder bottle on its side when you were done did you also open a bleeder to let air back into the MC or was the level just OK by itself?
Thanks,
Adrian
Carrying that a step further, keep a spare cap handy and you can seal and dispose of the old fluid right in the drink bottle. Make sure it doesn't look like diet pepsi in there though!
Thanks,
Adrian
Hawkeyes
