Two test ports on back of motor ?
The two metal test ports with the rubber caps on the back of the motor attached to the intake manafold; I believe they went to the cats. With the X-pipe, cats removed are they still necssary?
928 Engine Re-Re-Rebuild Specialist
Mine were both rusted and leaking. I removed them and plugged the holes on the exhaust manifold with locally purchased bolts. JB weld sealed them in place.
Man of many SIGs
It isn't a bolt thread. Using a bolt isn't the proper way to seal them. There are plugs available to seal them. You can match it up at a specialty hydraulics house if they carry alot of metric fittings. Roger also sells them.
