Air Temp switch routing ?
Any one know the routing of the Air Temp cable located in the Alternator hose. It disappears in the body and I think I may have a break in it or an issue on the control end. Before I start tearing things apart I need to check the wire itself. After I did the front end work, MM and oil pan work Heater Valve stays on. The sensor is good and it worked before the rebuilding.
Team Owner
see my post on fixing your HVAC system you might have damaged your cable
