Help with ticking noise
I have an 84 928S that hasn't been driven much (less than 100 miles) in about 2 years. I started it the other day and a rather loud ticking type noise came from the engine. The oil pressure and level seems fine. It has about 1/4 of a tank of gas that is alos 2 years old. I say this about the gas because I was curious if this could be the problem. The noise gets louder as I rev the engine. Any help to what this problem may be would be greatly appreciated.
Thank you in advance,
Mark
Mark
Hopefully it's one of the previous suggestions. It is common for rear exhaust studs on16 valve heads to break or fall out. If it is a sticky lifter try this and then change oil and filter. Works very well.
http://www.crcindustries.com/auto/co...x?PN=05331&S=N
Thank you for the help. I ran the engine cleaner through the car and changed the oil and the noise is gone. Hopefully for good!
Mark
Mark
