928 Forum 1978-1995
Sponsored by: 928 Specialists
Throttle position switches normal behaviour
Old Apr 29, 2007 | 03:08 PM
kjurkic's Avatar
kjurkic
Default Throttle position switches normal behaviour
Howdy all.
(1980 US928)
I have my intake all apart for fuel/vac/heater hose replacement & was fiddling with the TB switches, and noticed that they weren't activating (tested with multimeter). I have looked at the wiring diagram, but am unsure of the normal switch behavior. At present the WOT switch is staying closed, UNTIL throttle moves to activate, which opens the switch; this seems to be the reverse of what it should be according to the manual - but I may be cross-eyed.
Can any generous member enlighten me as to the proper operation of these switches?
I found some posts that explained what these switches do, but nothing on normal open/normal closed - admittedly I blasted through them pretty quick
TIA
Ken
Old Apr 29, 2007 | 06:16 PM
Tampa 928s's Avatar
Tampa 928s
My 86 at idle one pin is shorted to ground at WOT the other pin is shorted to ground.
Old Apr 29, 2007 | 11:31 PM
kjurkic's Avatar
kjurkic
I think on the 86, you have a TPS rather than 2 separate switches?
Ken
