Need help with harness routing
Does any one have pictures of the EFI harness routing on an 81 or know where a routing diagram is located? I'm converting from CIS and can't seem to locate the proper routing and where it goes through the fire wall.
Team Owner
I thought the wire harness went thru the firewall just in back of the right side exhaust manifold, and partially hidden by the cooling tank
Well my original CIS engine had the front body harness that went through that area but the EFI engine harness I have is seperate and it has the same style firewall grommet on it so I assume it must go through somewhere else.
