V1 32V'r updated manual + alignment bar
Inventor
I updated the manual for the old school tool, and figured out an alignment bar for it too!
These brings the old tool up the V2 standards.
Right-click, and select 'Save Target As...': (32V'r V1 Manual)
![](https://members.rennlist.com/porken/32VrV1AlignKit.jpg)
alignment bar
alignment bar
Inventor
For the alignment tool, or for a description of the new version, V2, of the cam timing tool, click on the pic above, or (here).
The bar is made of two pieces of 1/2" aluminum angle, one 5-1/4", and 2-1/4" long. There is a notch in the longer piece, 5/8" long, 1/8" deep, 5/16" from the end to fit over the side of the tool. (I rough sanded the two pieces and used polyurethane glue to bond them together.)
Good going, Ken. I love my 32V'r tool for fine tuning, and for making sure that I put things back on the car the way they came off. It's a tool that is affordable and easy to use. I'll be using my Ver. 1 again next week when I pull the cam gear and replace the stuff behind it.
The next time I check the belt tension on my 968, I'll see if it might work there too.
Harvey
Harvey
Supercharged
Sorry to bring this up, as I remember this horse being beaten several times, but can't seem to find the thread that explains it.
In the updated manual for the 32V's V1 (this is the one I have), it says each hole represents 2 crank degrees.
It then says, a good factory setting is US Driver side = 2* advaced, and Passenger side 1* or zero.
Question: Is this crank degrees or cam degrees (manual doesn't say)? Actually a better way to ask is, Do I want the Driver side cam to line up with the 1st or 2nd hole left of center? Remeber I have the V1, not the V2.
Inventor
In the updated V1 manual everything is crank degrees.
For 2° crank advance, and zero for a cold engine with a V1 32V'r*:
Cyls 1-4, zero hole
Cyls 5-8, first hole left of center (when looking at tool)
For future reference, I suggest you write a '+' sign on the left and a '-' on the right sides of the zero hole with a Sharpie to indicate advance and retard.
*The V2 'zero' is 2° advanced compared to the V1, so the instructions are different.
Cyls 1-4, zero hole
I have the V1 also but its been a while since I used it.
IIRC the factory settings are crank degrees.
Supercharged
Thanks guys. That's what I thought, but wanted to make sure.
I already drew a picture of the indicator with the + and - to remind me to mark it with a sharpie.
This is a great tool that PorKen built. Anyone who changes T-belts and does a little messing with engines should have one. It's one of my most treasured acquisitions...along with the easy to use belt tension tester that the dealers sell.
H2
H2
