Need cam seal install tool 16v 84 euro NO.VA.
I need the cam seal install tools. Can they be borrowed, rented? I am located in No VA.
Big AL in Virginia
84 928S euro twin distributor monster
Big AL in Virginia
Hmmm OK I am a bit surprised. This counters all I have read. They sy the left cam shaft has a taper and slides on easier. But, the right has no taper and the tool helps to spread the seal over the shaft.
No offense but I think I will hope for some more feedback on this issue.
Thanks,
Big AL from Virginia
84 928S Euro with large piston cut outs twin distributor monster
Thanks,
put some oil on the running /sealing surface of the cam and the seal gently work it onto the cam and tap it home with a large socket or piece of pipe that fits the OD of the seal , it should work out fine. otherwise you can use the flat side of a paint stirring stick and gently work around the edges flat side to the seal
Well, OK I will give it a try. Thanks for all your input. I was skeptical at first given all the feedback I have read about problems when not using the special tools.
84 928S Euro with large valve cut outs in pistons, twin distributor monster
who where you asking? the tool manufactures or retailers?
Well, the socket and a bit of oil on the leading edge of the seal is perfect.
I had no trouble at all getting the seal on. It went on so well, that I have 100% confidence in the install. Thank a bunch to all. This network on Rennlist once again proves its value to me.
Big AL of Virginia
84 928S Euro with large valve cut outs on the pistons twin distributor monster
