928 Forum 1978-1995
Sponsored by: 928 Specialists
o2 sensor question
Old Apr 7, 2007 | 03:55 PM
ceedee's Avatar
ceedee
Default o2 sensor question
my engine runs funny , when i connect the o2 sensor. what's up with that?
replacing the o2? or keeping it unplugged?
doesn't unplugging make the car run rich?
any ideas?
Old Apr 7, 2007 | 05:16 PM
928DK's Avatar
928DK
maybe u need to use another code plug when connecting the o2 sensor
may switching from "ROW without cat" to -> "ROW,USA with cat" will help (87 and newer cars?)
see pic : http://www.pff-online.de/wbb2/attach...chmentid=22820
as far as i can remember u have to bridge the o2 sensor connection when it is not in use (maybe i'm wrong, can anyone clarify?)
unplugging the o2 sensor should get the LH box to go into "emergency program"
sounds like the o2 sensor is faulty though (if the right plug is present)
Bernhard
928 dot dk
'87 S4, x-over,rmb,cats
Old Apr 7, 2007 | 06:52 PM
ceedee's Avatar
ceedee
yeah please do clarify...lol
i don't think it's too good to have the o2 unplugged
Old Apr 7, 2007 | 07:40 PM
John Speake's Avatar
John Speake
Ceedee - what MY ?
Old Apr 7, 2007 | 08:16 PM
ceedee's Avatar
ceedee
Originally Posted by John Speake
Ceedee - what MY ?
sorry it is a '81 928 4.5l
Old Apr 7, 2007 | 08:21 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Ceedee, add your car specs to your sig. Change your O2 sensor. You should be able to splice in a cheaper Bosche unit. I used a Bosche 02 sensor that had a "Ford" plug. I just snipped the plug and spliced it onto my plug.
Old Apr 7, 2007 | 08:34 PM
Mike Frye's Avatar
Mike Frye
Craic Head
Ceedee,
+1 to what Fabio said. Has the idle or timing been adjusted since the O2 is out to make it run smoother? Maybe replacing the O2 will require getting it back to 'spec'?
