Suddenly no 1st, 3rd, or reverse. Why??
Man of many SIGs
I am posting this for CeeDee. He is currently driving home with only a few gears. He said that he lost 1st, 3rd and reverse. If he tries to put the gearshift lever in any of these positions it will pop out when he releases the clutch. The other gears work fine. He can also get it into 3rd on a downshift from 4th.
Any ideas???????
Any ideas???????
Electron Wrangler
Probably the gear mechanismm locator cup at the front is falling apart. Tell him to try to get it into gear using 2 hands on the stick (I know tricky) OR grab the stick in the middle (not by the **** on top) and pull it into gear managing the angle of the stick to be as intended - see if that helps?
basically when the cup falls apart your pivot point gets out of whack - or in the worst case is totally gone... BTDT
Alan
Alan
The ballcup he is talking about is on top of the TT towards the front of the car. It cannot be seen from inside the car, and you can only see a glimmer of it from underneath the car.
look what i found under the dust cap. i think this is why it isn't working.
it is called a shift rod coupling. or better the rubber bushing. now where can i find one? autozone?
this is what it looks like
any ideas?
any ideas?
Captain Obvious
Super User
Super User
Originally Posted by EC928NC
Yep, you'll need to drop the exhaust and heat sheild to replace.... unless your arms are very very thin. New cup/rod end is way pricey.....
See my previous question answered here
alright got it all sorted out.
didn't have to take anything off . but the dustcover. (the only casualty, apart from the bushings)
i went to an autoparts store and bought bushings that had the same outside size as the old bushing
then i drilled the inside to fit the same as the old bushing.
now. the new bushing is not as hard of a rubber. so i don't think it will keep up for another 30 years.
maybe just a year. or a week. but now i know how to tackle it and i'll venture out and get some hard bushings that will fit exacly.
case closed
case closed
Captain Obvious
Super User
Super User
Hmm I replaced the front cup a couple years ago and still have a very loose shifter, maybe, just like you, my rear coupler is toast too. Good thing to know that its easy to get to. I'll look at it in a few days!
Originally Posted by heinrich
It's downright unnatural, that 2-hands-on-your-stcik thing. maybe he can have the GF help?
wha? you mean having to use two hands to hold it is not the norm?
