928 Forum 1978-1995
Sponsored by: 928 Specialists
One man's tensioner solution
Old 03-15-2007, 09:12 PM
  #31
6.0-928S
6.0-928S's Avatar
Originally Posted by marton
I can not believe that Volvo would build a tensioner that had different design requirements (in concept) from the Porsche one. I mean that it would be designed to maintain the correct belt tension as the motor cycled from cold to hot, etc.
Marton
Thanks Marton,
That's exactly the premise which started me on this idea!
Hammer
Old 03-15-2007, 09:15 PM
  #32
6.0-928S
6.0-928S's Avatar
Originally Posted by 928ntslow
Hammer, I think the reason some of us are making comments just beyond observing, is because it certianly would be nice to have a tried and true tensioner that does NOT need to be adjusted manually. As Jim said, most belts aren't even close to spec...and I know this first hand from checking several myself. It's a wonder there aren't more failures! This is an important subject because it is the difference between peace of mind having an automatic, reliable, constant belt tension and ...well, catastrophic failure. Stuff like dis get attensheeown!
Hi Keith,
I agree. I pursued this for that reason. I want to build the motor, set the tensioner & forget it. There's too many other things that also need attention on the car. I like, no, love the 928 concept. Just tryin' to polish it.
Hammer
Old 03-15-2007, 09:24 PM
  #33
atb
atb's Avatar
Hammer,
Willing to share a part #.?
Old 03-15-2007, 09:44 PM
  #34
6.0-928S
6.0-928S's Avatar
Hi Adam,
Off the top of my head, 30730060? (I'm at home with beer & company.)
You obviously discard the leverage assembly. It changes the dynamics & would make it unsuitable for this application.
Hammer
Old 03-15-2007, 10:11 PM
  #35
atb
atb's Avatar
Thanks Hammer,
Should be close enough.
Old 03-16-2007, 02:32 AM
  #36
G Man
G Man's Avatar
Great idea. Is that a Volvo Part #? I ran the # on the RA website and got no results. Can you tell us what model that tensioner is from?
Old 03-16-2007, 10:11 AM
  #37
Vilhuer
Vilhuer's Avatar
Porsche designed washers to contract x distance when they heat up. This x can be measured by experimenting same as its possible to measure what Volvo part does when its heated and cooled. If both give close enough results then I can't see any problems on updating to Volvo part.
Old 03-16-2007, 10:40 AM
  #38
Mike Simard
Mike Simard's Avatar
Hammer, congratulations on the excellent work. Please allow me to babble about tensioners while everyone's here.
Sounds like a damped spring would be ideal as long as the force applied by the spring was enough to tension the belt tight enough and the damping was enough to prevent flutter and allow it to slowly move with temperature change.
That seems simple, what's missing? Is the reason Porsche used the 928 system because it requires more force on the belt than a spring plunger would allow? Blown87 once made an observation that the tension specified for a 928 is much more than he sees working on other cars. Did the Porsche engineers feel that they needed to really clamp down on the belt and not permit it to fluctuate? Who wants to get a job at Ferrari and see what they do with their modern V12's. They seem to have a long timing belt on the new generation 612 engine, I wonder how they tension it?
Old 03-16-2007, 10:42 AM
  #39
6.0-928S
6.0-928S's Avatar
Ooops. Try 30720060. See what a few beers can do!
Hammer
Old 03-16-2007, 11:30 AM
  #40
Shark Attack
Shark Attack's Avatar
Originally Posted by JKelly
Very cool. I hope it works!
yes for the sake of the valve train.
With all due respect:
you are a brave man. that idea looks GRRRREAT... but you have a lot at stake if it doesn't work. You got ***** buddy, I like that in a fellow p-guy.
Old 03-16-2007, 11:56 AM
  #41
AO
Supercharged
AO's Avatar
HEY EVERYONE! SHARK ATTACK LIKES OTHER P-CAR OWNER'S *****!
(Hey, It's Friday!)
Old 03-16-2007, 11:59 AM
  #42
Mike Frye
Craic Head
Mike Frye's Avatar
OOHHH Shark Attack, you gonna take that?!
FIGHT FIGHT FIGHT
Old 03-16-2007, 12:17 PM
  #43
marton
marton's Avatar
Posted by Garth
HTML Code:
experienced a significant shift with as little as 1/4 turn when
near the optimum ..... which is ~0.25mm.
Marton
Old 03-16-2007, 12:18 PM
  #44
heinrich
928 Collector
heinrich's Avatar
(Hey, It's Friday!)
sick and wrong
Old 03-16-2007, 12:30 PM
  #45
Angel84-928
Angel84-928's Avatar
(Hey, It's Friday!)
Now that is funny!!!
Quick Reply: One man's tensioner solution
