LSD rebuild-able?
#76
Rest in Peace
Rest in Peace
Guys this is pretty straight forward. My trans guy has been doing this for years for us and a few other customers. As I told Carl you just need to offset the carrier with shims. Hopefully Carl can make these and offer them to everyone to make this simpler. The 78-82 LSD is better and easier to come by.
I have both LSD's are you saying with a little work/ my OB LSD can replace the one in my G28/13 ?
#78
First, we took the two LSD's (early and late) to a CMM machine to measure to the ten thousandth of an inch the location of the ring gears relative to the bearings. Then we swapped the ring gear over to the diff and measured again.
This let us know precisely what we had to make up in shims and in which directions.
Upon installation, we checked ring and pinion backlash agian and found it was spot-on at the Porsche spec.
We also used Prussian Blue to check the smear pattern on the gear teeth, and it was also spot-on.
But finally, we mounted it in the car and went and ran seven 30-minute race sessions with it. We were testing the LSD and also our brand-new solid transaxle mounts (photo below).
Both perfromed flawlessly. The serial port on my accelerometer is not working right, and although it recorded the sessions, we have been unable to get the files off of it. We will. And I am sure the traction circles they produce will show clearly the lateral and acceleration forces were improved by the improved limited slip.
Before everybody gets all excited about solid transaxle mounts - they are for cars equipped with rollcages only. There is twist in the unibody, and a solid mounted transaxle would be a mistake when the body is permitted to twist.
However, if rollcaged, the cage has augmented the unibody and will have eliminated the need for rubber mountings so the transaxle can float. I was surprised at how much the solid transaxle mounts improved the shifting accuracy and speed. More on that product later.
Contact pattern should be centered on the ring gear tooth between the root and top of the gear tooth. By your picture, it looks like the pattern is more towards the root of the tooth, which if so, would prematurely wear your ring and pinion gear.
. As away you made another great product.
Centered contact pattern set with a ring and pinion tool.
