I Polished My Rod
Originally Posted by Fabio421
That looks very nice Randy. I really like the spider. Was that the Cabriolet? Speaking of which, has anyone gotten a status on that thing from Tarek? He hasn't been around lately.
Tarek still comes around here but he hasn't posted for awhile for whatever reason:
https://rennlist.com/forums/members/10239-tarek.html
Originally Posted by Angel84-928
Very purrty!! ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I tried to get mine off but could only get 1 bolt off on each side. I was worried about stripping the allen head so its on the back burner for now.
heating them might be a solution
Originally Posted by Daniel Dudley
Randy, are you running without the fresh air pipes to your air filter ?
Used Mothers Metal polish on a lot of mine. It works great but you have to touch up once a month.
I don't mind that.
I almost didn't click on this link................dirty mind and all.
I don't mind that.
Man of many SIGs
SeanR. I used the mothers aluminum polish and followed up by a good cleaning until a white towel came off clean, and then I waxed it. The wax should keep the oxidation to a minimum.
Originally Posted by ceedee
burner is a good idea... i had lock tite on my bolts.
Do you need my spanner wrench for you shocks?
VERY nice, Randy! It's tough to get all the metal bits to look right. I notice your cam cover rubber plug strips are also a nice chromate, and the intake boots on the runners are correct. But please do me a favor and break loose with a few bucks to replace your washer reservoir cap.
Originally Posted by Randy V
On my '79 I painted the crossbrace with silver paint. Not too labour intensive and turned out pretty nice:
![](http://members.rennlist.com/randy_v/9%20Engine.jpg)
You will find that that stuff works great on damn near everything.
I need to update this pic, it looks better now......well not tonight, it's torn apart replacing vac stuff.
Originally Posted by JP Rodkey
VERY nice, Randy! It's tough to get all the metal bits to look right. I notice your cam cover rubber plug strips are also a nice chromate, and the intake boots on the runners are correct. But please do me a favor and break loose with a few bucks to replace your washer reservoir cap. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I actually did replace that cap after the pic was taken. This is all ancient history now, as all that work saw an unhappy end. The engine still looks good though:
If I heat the bolts they should expand and make it more difficult to remove.
i didn't mean super hot on the bolts, but enough to make the lock tite melt a little
Is the '78 steel rod stronger than the later aluminum one? I've read that it is a weak point. In fact, my rod is bent! It looks OK to the eye, but if you runn a finger along the underside you can feel ripples in the middle and in my perception I can feel that flexing under hard cornering.
Originally Posted by Mongo
So who else is polishing their rods looking at Fabio's sigline? ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
What other pics are there of her?
