New Shifter ball cup loose?
Owns the Streets
Needs Camber
Needs Camber
Man enters bar. Approaches tart sitting at said bar.
"Excuse me, miss. But can I have your pantyhose to fix my loose shifter cup on my 9-2-8."
New front shifter cup went in about 2-3 years back. It was the white plastic one.
The old one had a sliver of plastic rattling around the inside of the metal cup.
Ernest (NYC)
Ernest (NYC)
Ernest it is all how you say it ! ....Miss my ball cup socket popped of my shift rod and I have too much play could I borrow your panty hose to hold the cup on my ball.... Yea , that should work...
Well I've decided to go the "Macgyver" route to eliminate the slop. I will post photos if any one wants to see my modifications. Jim, now you can bust my chops for non Porsche approved modifications.
Originally Posted by John Veninger
The ball cup will wear out prematurely if the zip tie or hose clamp is on to tight. The plastic cup will start cracking. The zip tie it just there to prevent the rod from popping off.
If the cup went on tight, then your issue is with the rear coupler.
Right- I installed a new cup, which had to be forcibly pressed onto the ball- then a 6" hose clamp loosely around the shaft @ the "flat-spot" - It's Money...
