Shift points for 86AT
I found the shift points for the three speed in the morehouse WSM, but nothing for the four. Mine seems to be shifting at a higher RPM than it used to after a tranny service. ATF at temperature is right between the min and max.
KK
KK
Check Page 38-105.
Volume II covers the three-speeds, Volume III covers the four-speeds.
Shift speeds are controlled by several factors, including the adjustment of the throttle-to-transmission cable. Unlike American cars, the vacuum modulator has very little effect on shift speeds.
Originally Posted by BRETT AINLEY
Hi
My 86 16 valve (310 hp)
Changes under hard kickdown at 5900 revs
1/2 = 44 mph
2/3 = 77 mph
3/4 = 117 mph
All the best Brett
1/2 = 44 mph
2/3 = 77 mph
3/4 = 117 mph
All the best Brett
My '85 EURO (same motor) is:
1/2 - 40
2/3 - 82
3/4 - 130
