Need cheap used tires
My shark is in need for an alignment but I dont want to drive it on my new tires to the shop (yes its that bad) so does anyone have some used 17" that fit my cup 1's? Im not exact on tire size right now Ill check when at home. Yhanks
Have you consider your nearest u-haul store and get a dolly (no affiliation, lol)?
It may be the cheapest and quickest route considering you got something to haul it with.
Iv got two Toyo Proxes 4 17" fronts - There were on OEM GTS wheels before I replaced them with newer Proxes 4 -
Let me know if your interested - Im currently at work but later I can send pictures if you would like.
I'd get a U-haul and take the car down there myself. When you weigh the cost of the rental, versus the cost of mounting and balancing two sets of tires, in addition to the cost of the set of used tires, they'll both come out to near the same price, but one requires a lot more work.
Originally Posted by Mark
DO NOT tell U-haul you are wanting to tow a 928...they won't rent to you!!
Maybe someone near you has a car hauler trailer they can lend you.
Captain Obvious
Super User
Super User
Originally Posted by mark anderson
You should be able to get the alignment close enough by eye to drive it.
I agree. Use a tape measure to get the centers close. Also you need good tires (evenly worn) to get an accurate aligment.
I have two used Pirelli P-Zero Rosso Asemetrico rears. 285X30X18. Measured tread is 7/32nds. Sixty ($60) dollars for both. I also have two used Dunlops FM 901s 265x35x18 with 6/32nds tread. I'll let them go for $50 for the both.
I have more than once in the past done an alignment very accurately using 2 framers squares (the large 18” x 24” or thereabouts) and a tape measure (and a helper)
Make sure the car is on a decently flat surface. Take one framers square and set it on the floor near the back edge of one of the tires (maybe one or two inches in).
Take the other square and do the same thing with other tire.
Take the tape measure and measure on the floor the distance between the squares.
Move the squares to the front of the tires (on both sides of course) then measure the distance (at floor level) between them.
I usually set the front about 1/16” smaller than the rear of the tire. (Went to SITM ~2500km) after installing a new tie rod, without wearing out my tires and had no control issues (well maybe self control issues)
Originally Posted by icsmike
I could put a couple rounds of duct tape on my 17's and Id bet they would fit
Toyo Proxes 4
I sent you a PM with my asking but we can always work a deal.
There is some uneven tread wear - one tire worse than the other and other isnt bad at all.
