Changed brake fluid - air in the lines?
In my opinion, the power bleeder kicks butt over the manual press-and-squirt method. Over the years, I have managed to accidentally pump the reservoir dry a few times using the manual method. It takes two people, and you have to train your pusher to stop a little off the floor and acll out the pedal positions so you know when and which way to turn the bleeder screws. Contrast with the power bleeder: One person, set it up on the MC, then just walk around from wheel to wheel, opening the valve until fluid flows clear then closing. It just couldn't be much easier.
The speed bleeders are a one person process, and IMO do a great job of bleeding. Again, I must emphasize that I keep a watchful eye on the M/C reservoir to avoid running dry and sucking air.
In regards to the pressure bleeder, I think it is a great tool. The reason why I used it to drain the reservoir was so only a small amount of the old fluid would mix with the new fluid. But I normally syphone it out of the reservoir rather then using the empty speed bleeder to push it out. The reservoir was not completely empty and air started to come out the rear line I was bleeding. So I won't be trying that shortcut again. There is no issue with the speed bleeder and fluid levels. If the reservoir is at the full mark, the pressure bleeder will keep it that way, since all pressures equalize. There is no need to prefilling the hose going to the reservoir.
My pressure bleeder manual asks for cleaning with denatured alcohol and that works really well. No need to go in there with a rag or paper towel and contaminate it.
Thanks,
