SFR Smokonator presure tester-$49.95
I bought a SFR Smokonator presure tester for $49.95 from SpeedForceRacing http://www.speedforceracing.com/prod...ewproducts.php
It works very well, although Rob said his shop smells like a bingo hall after using it. It showed a small vacuum leak at the rear opening of the SC. So that will get some yamabond and it should be done. It looks as if the snow will be gone so we can do some initial street tuning with the wide band later this week.
Administrator - "Tyson"
How / where did you hook it up? Sounds interesting. Any pics since their site doesn't have any?
It is a tube with a holder for a cigarette hooked up to a pressure regulator. You just make an airtight connection and start blowing smoke. The end is a vacuum hose so you can put it on a vacuum port.
