928 Forum 1978-1995
Sponsored by: 928 Specialists
Interior rehab and upgrades including Carpets, Leather, Lighting, and Electronics…
Old 02-16-2007, 10:36 PM
auzivision
auzivision's Avatar
Default Interior rehab and upgrades including Carpets, Leather, Lighting, and Electronics…
Thanks to all the inspiration and knowledge that can be garnered from this site, I have decided to perform a number of upgrades and modifications to my interior. In stead of beating around the bush, I’ve decided to do it all at once while attempting to stay within reason and budget.
Following is a list of items I intend on working in the next several weeks. There is no way I would have considered or even known about so many options if it weren’t for this site… for that I am grateful. Since I am a bit lazy, I’m hoping that posting my ambitions for all to see will help motivate this project while offering opportunities for others to help fine tune.
# Item Material Source
1 Carpets GAAH, 3M Adhesive, Clamps and Roller Paul
2 Seats Rejuvenoil, Pristine Clean, Dye Leatherique
3 LED's LED's Nicole
4 Sound Deadening Raamat Hans
5 Pod Leather Cover Paul
6 X-mission Indicator Bulbs Radio Shack
7 Fuel Gauge Replace gauge and/or Sending unit (and fuel Filter WYATT)
8 Pod LED'S LEDs Nicole
9 Sill Plate Lighting Electro luminous light eBay
10 Remove old Alarm N/A N/A
11 HVAC LED'S LEDs Nicole
12 Keyless Entry Remote Controller Commando KE-30
13 Lock & Ignition Overlays Nicole
14 Rewire Stereo Wire, RCA cables Ovation/Fry's
15 Sub Infinity Basslink or prewire for custom box Ebay
16 Hardwire V-1 Black Telephone connector Frye's
17 Electronic Mirror Donnelly, Gentex, or ? eBay or Elkhart
18 Fix Console Repair Bracket Nicole
19 Switch & Connection Stabilant,DeOxIt, Dielectric Grease, Control Cleaner Radio Shack
20 HVAC Relay Relay, wires, connectors EuroMotorsports
21 Antenna Roof Antenna and cable, possibly shark fin ???
22 Door Panels Clips and brackets 928 Int./Spec
23 Arm Rest Repair Metal Brackets Nicole
24 Door Arrest Kit Nicole
25 Fire Extinguisher Fire Extinguisher & Bracket
26 Cup Holders
27 Console Panels Panels behind carpet
28 Seat Bolts Rounded Allen bolts
29 Clock Reprogram to 12 hour clock 928 OC instructions
Please feel free to chime in at anytime. I have a ton of questions and pictures that will be following soon. Hopefully others will gain from this quest.
Old 02-16-2007, 11:33 PM
Ed Hughes
Ed Hughes's Avatar
That's quite a list! Keep us posted on your progress.
Old 02-17-2007, 01:09 AM
Alan
Electron Wrangler
Alan's Avatar
Yeah Yeah couple of weeks....
err... well you might want to start planning in months for that there list....
That is alot of stuff to do... I have done many of them and some of have individually taken me over a year to complete to my satisfaction (OK OK so I admit I'm a perfectionist - but still....)
Alan
Old 02-17-2007, 01:23 AM
928ntslow
928ntslow's Avatar
Yea, its optimistic and took me quite some time as well to complete a similar list for my 82. Just know that this list of yours will grow before it ends. Best of Luck!
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Wow - Kurt, it sounds like you're going to be busy for a while! But it'll be so much more fun to drive afterwards, when everything is perfect...
Old 02-17-2007, 01:53 AM
heinrich
928 Collector
heinrich's Avatar
pics
Old 02-17-2007, 10:33 AM
auzivision
auzivision's Avatar
I know a few weeks was not really what I'm thinking either. Absolute drop dead dealine is SITM, but I really hope to have it done by sometime in April.
Not much to show yet... still in the dismantling stage. I hope to have the rest out this weekend. Then start on the stereo wiring and Raamat. Hans is going to stop by to help out and give me some pointers.
Should be fun...
Old 02-17-2007, 10:38 AM
auzivision
auzivision's Avatar
First question, do you think these seats are good Candidates for Leahterique? I’m a little worried about the piping. If it doesn’t come out good enough, I found a local shop that will replace all piping for $300. Does that sound about right. If I go this route, I’m switching to black to add contrast.
Old 02-17-2007, 10:51 AM
Ed Hughes
Ed Hughes's Avatar
If you're going to all of this trouble, what's an extra $300?
I'd do the contrasting piping, it will help set off all of your work.
Old 02-17-2007, 11:07 AM
hans14914
hans14914's Avatar
Kurt,
I would try touching up the bolster with SEM first. There is a paint supply place down on Illinois, just north of 16th street. I think its called G&M or something like that, on the west side of the street. They custom mix SEM products, they also have the SEM leather putty if you think you need it. SEM can be sprayed on in very light coats to get a nice finish that wont hide the grain or run like other products can if not applied properly. If you need a hand, give me a call. I will be in town all weekend now.
Hans
Old 02-17-2007, 04:19 PM
Nicole
Nicole's Avatar
You might be able to get the seats decent looking again with dye - but they won't be perfect. If you go the black piping route, don't forget to do the rear back rests also - otherwise you'll have a mismatched interior.
Old 02-17-2007, 05:43 PM
Randy V
Randy V's Avatar
Thiis stuff works great:
https://rennlist.com/forums/showthre...ighlight=latex
Old 02-17-2007, 06:26 PM
85fortheDrive
Artist Formerly Known As 84totheFloor
85fortheDrive's Avatar
Kurt:
I expect these items to be completed before my arrival.
Also, let us know if, upon paying for your purchase at Radio Shack, you are asked if you need batteries.
Old 02-17-2007, 06:48 PM
123's Avatar
Did a source for the correct size of electroluminescent panels pop up on Ebay again? If so, anyone have a link or Ebay seller name? The lighted sills are one of the things on my list as well.
Old 02-17-2007, 08:12 PM
auzivision
auzivision's Avatar
Thanks for the tip... I'll definitely will do the front and back if I choose to go this route. The $300 quote was for all four seats. My biggest concern is will I like the results of recolored leather. If not, I'll have to save up and consult with Paul some more.
Quick Reply: Interior rehab and upgrades including Carpets, Leather, Lighting, and Electronics…
