rubber oil pan gasket coat with Oil, Rtv or nothing
Basic Sponsor
Nothing - make sure the surfaces are clean and dry.
Use a couple of small zip ties to hold it in place through a couple or more of the holes as you bolt it up.
Man of many SIGs
I prefer to hold my gaskets in place with weather stripping glue. Glue it to the pan and then install the pan with the gasket dry. If you use RTV or oil it will act as a lubricant and allow the gasket to extrude while tightening.
Basic Sponsor
Please do not use any sealants or glue on these silicone gaskets. They must be installed dry. Oil Pan surfaces must be clean and dry and grease free for best results.
HI Roger... I was about to ask this same question...
THANX for answering it already... I like your ZIP tie idea.
Makes the whole job so much easier if one is doing it solo ;-)
Matt... MMs and Sump Gasket job, using Roger's 928 Solid MMs and
silicone sump gasket on my '87 S4 Manual half way there ...
