Battery Tender
Jim
Manufacture is in Deland Florida, 904.736.7900
Neil
That said, they work great and you can't beat the price. A side note: anything that's on sale on H.F. website is not necessarily on sale in their stores. They will honor the online price if you provide a printout of the online ad.
I've had mine for a couple of years now (actually I have 4 for all 12v batteries, including boat batteries).
They're so cheap that you can't afford not to buy a few.
Mark's absolutely right. The lighter is an open circuit with the ignition off. Even if it weren't, I'm not too crazy about running power backwards through such an indirect route to the battery...but that's just me.
Here's a good way to set up the maintainer as a permanent plug n' go invisible fixture:
Replace the alligator clips with connector eyelets and attach directly to the battery.
Splice a quick connect plug into the power supply about 6" to 1' from the little black box.
The coiled cord and black box fits behind your tool panel with the plug peeking out.
When you park, you lift your hatch and plug in.
They are exactly that, chargers, not tenders or minders. A good unit will cost you more like a $100, and will monitor the charge and reduce it when the battery is at 100%, then maintain a trickle charge of a 100ma or so, so it doesn't overcharge the battery.
I've actually had a high end charger/maintainer overcharge my battery to the point of boiling the acid.
I learned that with any sophisticated charger/maintainer it is necessary to connect them directly to the battery as opposed to hooking them up through some convenient pigtail connection. If the gauge of the wire used in a pigtail is less than that of the charger connectors, the charger will get a false reading (resistance?) thinking that the battery has not fully charged. It will continue to put a charge on a fully charged battery.
small enough to fit in the battery space and be hard wired to the battery ( through a fuse of course!)
