Compressor replacment how to add oil ect!
I am replacing my compressor with one I purchased from Roger at 928s r us he sold it as a core but said it came off of a working wreck. I have changed out the clutch and need to know how much ester oil to add, is it 4 oz? Do I pour it in the suction side than connect the hoses and what about the remainder of 4 ozs how and where do I place that. I am changing my expansion valve it’s leaking badly. I thought I would do all this, vacuum it down and see what happens. If it looks good I will replace the receiver dryer. Does this sound like a plan since my belt job is finishing up I though this was a good time. As a foot note I have a brand x flush kit but for what I read I would have to remove all the hoses to the Condenser and not flush it. Also I heard that I should use some type of mineral oil instead of the ester oil on the seals. Any feed back!
I think ester oil if filling with r-134. Mineral if filling with r-12. I think the same with lubing the o-rings/seals. PAG (readily available with r134) is said to not mix well with r-12.
Add some oil to the drier. Also you can get ester oil in a can mixed with r-134 (if adding ester) to add into the system like you would the refridgerent. Specifications are available, but you need to make a judgement call as to how much is still in the system.
You should put half the required oil in the compressor and half in the receiver/drier. BUT, unless you flushed the system you don't know how much oil to add. The total listed in the manual is for a clean and dry system. Your system has oil in the condenser, evaporator and the lines. I would recommend flushing the system first. If your going to go to all that trouble and expense it pays to do it right the first time. No offense intended.
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
You can use the ester.
If this car was previously converted to R134a with PAG oil you would want to flush if you are going to use ester.... you need "enough" flush and you need to get it all out too. And please, do not overcharge the system. Use your gauges and go by a P&T chart.
I don't just sell parts, but I happen to believe that I do some of the finest A.C. work around.
Aside from being better off by resealing the whole system, here is the advice I will dispense.
Griffiths is entirely incorrect when he says that you can inject all the oil in the low side. That is a terrible idea as it can lock up a compressor. Do not do this!!!
Jim M is correct in his comment that you really don't know how much oil is already in the system, but I would guess no more than a couple of ounces. REPLACE the reciever drier anytime you open the A.C. system. They are cheap and critical to get good cooling and reduce corrosion to the a.c. system.
**** can the ester products. They aren't terrible, but they are not carried by freon R-12 as well as mineral oil. If you use R-134a, make sure to use a PAG 46 after flushing the system.
Ester was never approved by any major manufacturers for use of 134a.
Get someone that actually works on the cars, not just sells the parts. Good luck!!!
..... you really don't know how much oil is already in the system, but I would guess no more than a couple of ounces.
Years ago compressor remanufacturers and some new OE's use to ship compressors with a range of 2-4 oz in the compressor. However you never knew exactly how much because in most cases they did not note it. And as you know swash, wobble, rotary and scrolls compressors don't have dip stick (though Sanden does offer one however they are not easy to come by and we question their accuracy because of "wetting") so the client has no way of determining how much oil "may" or may not be in the compressor alone. Your only method of determining how much oil might be in the compressor is to dump out what is in there, measure it, include a factor for "wetting" (what wont' come out) and put it back it (SOP again).
So based on our experience (since 1984), and I'm not knocking yours, you would be safer to add more oil than not enough; in the worse case scenario you might lose some performance from saturation in the evaporator; I would rather minor lack in performance from an overcharge of oil than a locked up compressor in the case of not having enough oil.
A) changing oil types
B) questionable age of the drier
C) system contamination
Here at our facility we have retrofitted plenty of vehicles using ester, primarily Porsche: 911, 928's (including the three I have owned), 944's and 964, and never had a problem. As well, we have marketed over 1,000 retro fit kits to the Porsche community of which approximately 1/3rd are repair facilities and 2/3rds are DIY's. If you search the forums for Dr. Bob of Jim Sims you will also find plenty of good results using Ester. If a situation came about where there was a problem relating to an "oil issue" usually is not the type rather a problem related to either system or installation problems (not enough oil or lack of oil flow).
