Engine Braking, Does It Make Sense?
#61
Originally Posted by James-man
I have never heard of anyone clutching-in for brake zones. The guy that solely uses brakes in a brake zone ahead of a turn and does not downshift in there somewhere will SURELY be slower than the guy that does the engine braking downshift (along with brakes of course).
#63
928 Collector
Btw Sway Brother ... there is no effect on our gearboxes, of double-declutching. None. Step on it once, step on it twice, same diff. Gears turn and are not slowed down any better by double-declutching.
#64
Originally Posted by SwayBar
That is not what I said, or, I did not mean to imply it. Since we're talking about braking, I intentially left out listing appropriate downshifting as it was implied.
I will say this, I apologize if I misread or misinterpreted your statements. Hasty reading and hasty typing occurs at the kids' bedtime and I suspect this was the case.
#65
As long as there is no load not accelerating or engine braking the gears will disengage very smoothly if in doubt you can depress the clutch pedal but immediately let it back up while you come to a stop and wait to put it in gear. Everytime you push down the clutch the release bearing is put under very high loads as it bends all the spring fingers of the pressure plate to allow the friction disc/discs to move away from the flywheel. This also loads up the crankshaft thrust bearings but in the opposite direction of the automatic issue. Just more Blah blah blah... just drive it in a way that makes you smile !
#68
Heinrich I believe that you are missing the point of double clutching , If you are downshifting and the engine is turning 3,000 rpm and you are going to a gear where the engine will need to be turning 5,000 rpm the torque tube , input 5 th gear are turning the 3,000 rpm buy reving the engine clutch torque tube and 5 th gear input gear to 5,000 rpm buy letting out the clutch in neutral. The gears are now turning about the same speed which they need in the lower gear. The syncros have little or nothing to do as the gears now turning compatible speeds when they mesh. If you listen to the big Semi tractors as they are shifting they are matching gear speeds. Syncronizers are used to make shifting easier for people who do not now how to double clutch
#69
Jim,
Far be it for me to correct THE BIG CAHUNA, but double clutching and rev matching are not the same thing. Proper double clutching is NECESSARY when you don't have syncronizers.
#70
928 Collector
I was about to say what Ernie said Jim. Double clutching in heavy trucks is used as follows:
Drive.
Clutch in, take out of gear (starts slowing gears)
Clutch out (gets gears running at idle)
Clutch in, put into gear (gets gears spinning up to new gear)
Clutch out (engages new gear)
Drive.
#71
I tried coming to an intersection without the car in gear based on Jim's comments on an earlier similar thread. I didn't feel comfortable not having full control of the car as I was coasting, so I resumed downshifting. Luckily. A few weeks later, I approach a red light to turn right on red. As I am stopping, I hear the sound of locked brakes and skidding tires on wet pavement. Since I was still in gear, I was able to pull forward and give them the extra distance they needed. If I was in neutral, I would have been hit...
#72
To slow the car down, use the brakes.
The reason to row through the gears on downshifts 4-3-2, is to be in the in the powerband when you get back on throttle, no matter when that may be. Being in gear also can help w/ rotating the car during turn-in. This is a much more subtle and secondary effect.
Re: what Ryan is saying, Michael Schumacher has an electronic differential in his Ferrari F1 car that he can adjust for % of lockup during acceleration and braking, separately. He has two dials on his steering wheel which he is often futzing w/ down the straights, altering the behavior of the car on turn-in and corner exit. He's notorious for wanting an unstable car on turn-in.
#74
928 Collector
Originally Posted by ErnestSw
This thread is turning into the department of redundancy department.
