What doesn't work on your car?
#31
Headlight aim adjusters (crazy hydraulic system)
footwell and centre comb vac actuators (new footwell actuator on the way!)
de-icer doesn't turn off after 15 minutes (but I got the new relay yesterday)
D light in tacho
roof light above rear seats works only in 'always on' position (new light on the way)
aircon (haven't started looking at that yet)
D light in tacho
#33
* Passenger side door locks are flakey; always works on it's own, but sometimes not in sync when locked/unlocked from driver's side.
* Low fuel warning. The light goes on when I start the car, but I've never seen it come on when fuel is low. I've never run our though; maybe it comes on when there's 1/2 gallon left? I've never filled more than 20 gallons into it, needle points to lowest mark; what's the capacity?
* Center air vent blows unheated air when heater is on. Door, foot, defroster vents are OK.
* HVAC lights don't work.
#35
What doesn't work on my '88
- AC
- odometer
- AC flappy valve
- driver side alarm w/lock (passenger side works fine, electrical short I am sure)
- power steering leaks
- power mirrors (electrical short I am sure, they work w/3 way drivers adjustment)
I have replacement parts to fix
- AC
- odometer
- electrical shorts
Now if I could just find where I put the time to fix them??
Michael
- AC
- odometer
- AC flappy valve
- AC
- odometer
- electrical shorts
Michael
#40
Sunroof Switch and Cruise Control...
Do I have you all beat yet in the least amount of things broken?
Oh! And a false coolant warning light that just happened this morning
#43
Fleet of Foot
Option code 20MM isn't presently functioning. That is the trigger switch in the e-brake handle button that fires the 20mm Vulcan gattling gun carefully hidden in the front of the car. This option code is used to gently persuade left lane bandits to be a bit more considerate in future encounters with fast moving P-cars.
Oh yeah, and my washer pump is apparently siezed up!
#44
Michael
