S4 parts in an early 32V block?
Captain Obvious
Super User
Super User
Can an '87 S4 rotating assembly (crank, con rods and pistons) fit into an '85-'86 32V block? Also, will the S4 heads bolt up to the early 32V block? If it does, what modifications are necesarry?
You may have to use head bolts instead of the studs. Don't recall if they are long enough for the later S4 heads.
As Erkka stated, everything else is OK if you use the same tolerance pistons.
