Thanks and updates on the Havc
I found the Heater control valve bad I removed the arm and wired it to bypass I found the little fan in the temp sensor making noise just did a cleaning and now it's quite Yaahoo!. Now I need to work on the compressor it's not going on I need to hook some gauges to it, it worked for a while might be low. I'm trying to avoid the rebuild as suggested but will know more a little later. I just found some fluid leaking near the front I'm assuming its from the water pump BUT I have a whole kit sitting in the box waiting to be installed. I just wanted to do one thing at a time. I purchased this car in 2000 sold it to my son 2 years ago and just got it back. I'm in the process of fixing all the things that need to be done!
I want to thank all of the members for the help with these projects. I'm sure I will get band before I'm done with this car. After everything is done then the Turbo is next
