how to remove center air vents to access
Originally Posted by StratfordShark
Any tips please for materials/sources for apping vac lines? I saw a photo on one of the write-ups which showed short lengths of orange tubing capping some lines, as if it was heat shrunk. I can't think where I could get materials for capping the lines other than using the plugs from my Mity-Vac and Vac gauge kits but I'd like to keep these for testing uses rather than hiding them forever in the centre tunnel!
I have 2 lines to cap (centre and footwell) otherwise the other lines all work fine.
Will definitely replace the footwell vac actuator when I get hold of one.
Thanks,
Adrian
Thanks,
Adrian
When I capped mine I just used some 3mm vacuum lines caps I bought at the local auto parts store....they were cheap only a few $$
Tampa
That is odd....but the default mode (no vacuum) is fresh air through the center and defrost vents with constant heat (heater valve open)....it does sound like your setting motor isn't working, it might be stuck closed.....but I haven't had to fix mine yet?
Originally Posted by Tampa 928s
i understand the heat concept I guess I have two issues, yes a diagram would be very helpfull!
http://forums.rennlist.com/upload/92...stem_copy1.jpg
[QUOTE=IcemanG17]Adrian
Thanks for suggestion. I haven't seen caps in any of the auo stores I use here in the UK but I'll keep looking now I know they're out there! Sounds like a Google job...
Adrian
Adrian
