85 928s 5-speed turbo/supercharger ?
#77
Originally Posted by chris0626
Blowoff valves prevent backspin, not boost... a 'wastegate' is what limits boost.
Blowoff valve is mounted between the blower / turbo and the intake to limit boost pressure.
Kevin's was stuck open - so bascially like cutting a 2" hole in his intake. All of the boost was blowing out into the atmosphere. Or, until the amount of boost overcame the BOV opening, he saw a little bit of boost in the engine, but not much.
#80
Originally Posted by Hacker-Pschorr
Wastegate is mounted on the exhuast between the exhaust manifold and the turbo. Bleeding off exhaust pressure to slow down the turbo. There is no need or place to put a wastegate on a supercharged car.
#81
Originally Posted by John Speake
Hi Jim/kevin
OK, good the problem is solved. I seem to remember I suggested BOV in another thread Kevin ?
Is your a Stage 1 or 2 kit ?
#82
Captain Obvious
Super User
Super User
The SC kit that was for a '93 LT1 Trans Am (Paxton) never had a BOV/BPV or even an IC. If you are running low boost (less than 8psi), you can get away without having any of this. Just a straight tube from the SC to the intake, but you better have strong claps and hose to withstand the surge pressrue during throttle closure.
I hope this helps!
#83
My apologies... my experience is from turbocharged cars, not supercharged one's... I should have read better.
