Thermostat differences, need help
Originally Posted by marton
HTML Code:
The pump is dead so I took it out.
Marton
I finally got the correct size o-ring for the thermostat (I think), so it better fire up and roll or else.....
Hi
Jkelly Great news that the pump works
What page of the WSM teaches you to do that
Fingers crossed for "turning the key time"
Marton
HTML Code:
after I got the pump out and threw it in the yard, I hooked up the wires in reverse, and then correct polarity
Marton
The REASON why the fuel pump relay was jumped is PROBABLY that the LH Brain was failing and lost the ability to trigger the fuel pump relay...Having the pump run with the ignition is NOT a vey good idea if the car has or developes a leaky injector and some one leaves the ignition on like ti hear the radio, trouble shoot electrical, installing a radio etc. ....it can fill a cylinder with fuel and hydrolic the engine when you start it...bending the rod ,splitting a cylinder, blowing out the head gasket...
Marton
Marton
The WSM teaches us?
I came across the reverse polarity trick several times while doing research on new fuel pumps. The pump worked yesterday after reversing polarity, then today as I was getting ready to hook up the gas lines I thought I'd better try it one more time just to make sure............sure enough, it didn't run.
I went out to my gravel drive and repeatedly threw it at the ground thinking I would have to buy another one anyway. This clear gel-like stuff came out and it looked like half-dried glue or congealed gas or frozen gas; if that is possible, although it isn't freezing here today. Anyway, I tested it again and it worked just fine
. Even though it is all beat up looking now, I installed it and ran the car for awhile and watched for leaks. Those pumps are very tough!Anybody have any idea what the gel stuff could have been? old gas from sitting for the past 1 1/2 months?
P.S. The thermostat housing isn't leaking (yet) either. I think it is time for a test drive!
HTML Code:
HTML Code:
Sounds like you cleaned out the bottom of the gas tank by the usual technique of spraying it over yourself so hopefully no more gel problems.
marton
I finally got to go for a nice drive this afternoon
No problems.
Just to be on the safe side, I did drain quite a bit of gas when the fuel pump went back in and then filled er up during the drive.
It's good to be back on the road. Thanks everyone for the help!
No problems.
Hey John,
Way to go. How did this repair go over with the SO? My wife made me swear to never do another gas tank anywhere near the house. I swear, it took me 2 weeks to get the gas smell off my hands and arms. And, yes, I wore gloves. Gas seems to have a way to get everywhere.
Good luck
Good luck
Originally Posted by fbarnhill
Hey John,
Good luck
Good luck
She only complained twice and it was gentle complaints. I had it all over my hands and arms too, even after scrubbing them good, so I resorted to soaking in the bathtub
. That works better than anything.
