928 Forum 1978-1995
Sponsored by: 928 Specialists
Burnt reverse clutch pack?
Old Dec 1, 2006 | 05:02 PM
kurtb234's Avatar
kurtb234
Default Burnt reverse clutch pack?
Hello all,
I have an 82S auto, and was alittle low on fluide, took 3 1/2 quarts to fill
The tranny slipped alittle in reverse before, now after filling, it will not back-up at all. When on the lift, the tires do move in rev. but the car will not move backwards! major inconv.! Any suggestions as to what I should look for?!?
Old Dec 1, 2006 | 06:14 PM
Jim bailey - 928 International's Avatar
Since it only holds about 6 liters TOTAL it was maybe more than "alittle low on fluide" when it took 3 1/2 quarts to fill it back up. The reverse brake band has an "adjustment" a shear bolt with lock nut which is factory set and the head of the shear bolt broken off so no one ever mucks with it BUT you can try to tighten the shear bolt by carefully loosening the lock nut and tighten the shear bolt a little. Mark it before so you know where you start. If that does not work with a little adjustment then more likely than not the piston/seal on the other side of the transmission is leaking and not able to make enough pressure to engage the brake band.
Old Dec 1, 2006 | 07:52 PM
kurtb234's Avatar
kurtb234
Where would i find this ajustment? Where is it in relationship to the filler/sight tube?
Old Dec 1, 2006 | 08:35 PM
Steve Cattaneo's Avatar
Steve Cattaneo
This will help you.
http://www.mercedesshop.com/shopforu...t=REVERSE+BAND
Old Dec 2, 2006 | 02:28 PM
kurtb234's Avatar
kurtb234
Thanks Steve! the pictures are great!!!
Old Dec 2, 2006 | 02:31 PM
Shark Attack's Avatar
Shark Attack
why would they break that off? just wondering
