Fuel injection cleaning - StaBil
Owns the Streets
Needs Camber
Needs Camber
So will Stabil help clean off the varnish deposits on the gummy/sticky fuel level sender float wires?
Ernest (NYC) "Best Guess" brand fuel guage.
Received 1,597 Likes
I dunno about StaBil but Techron seems to do the above.
Adding 'cleaner' to a very dirty fuel system might be problematic. I've seen one case where Techron broke loose enough varnish to clog up the fuel pump check valve. (And it didn't fix the sender.)
