AC not working question (UPDATE!!)
Darien
Does the fan work on all speeds? The reason I ask is when my "fan blower relay" started acting up at sharktoberfest the entire system did NOTHING.....no blower....the a/c switch wouldn't light up....nothing at all......a quick wiggle of the relay and all is good!
Hi Brian, yup the fan and climate control are still working. I haven't had time to check the switch connector, plus it's not very hot right now Hopefully this weekend I'll pull the side panels and take a look.
Originally Posted by IcemanG17
Darien
Well, a 5 minute fix, just like I like it Took the driverside panel off and there she was, the AC button connector disconnected. Connected and AC working
Thanks all
Thanks all
Originally Posted by Constantine
My vote is what Dr. Bob said. Just went through this myself when I replaced the evaporator core. That little plug on the back is notorius for popping off the back of the AC switch. Remove the drivers side trim panel to the center console and look/feel behind there. If you were mucking around with your stereo as you said that is probably the problem.
Good luck,
Constantine
Good luck,
Constantine
Thanks all
Thanks all
Right on!! I love it when you can fix a 928 & not have to buy anything!
