88 928 failed et on co
fighting problem w/adaptation,keeps adapting full rich w/new air mass meter, coolant temp sender, o2 sensor,no vacume leaks,the only thing i don't have to try is known good ecu. If anybody hit this wall let me know thanks mike 303-601-3091
Are you sure that it is going full rich? While that will cause high CO, it most likely will also cause high HC. I am not sure what the '88 has but if there is an air pump you may not be getting the air needed for the cat to deal with the CO created.
