S4 Jack Bracket
S4 Jack Bracket
My jack bracket (the rubber strap that is supposed to retain the jack behind the tool kit) needs replacing. 928 specs does not list it and Pelican lists it as a superceded part but can't source either the original (91472202110) or superceded number (91172202101). Any other suppliers out there?
thanks
Jason 89S4
thanks
Jason 89S4
Yes they do hold the warning tringle and the wheel nut brace. I've tried to get the jack in there but couldn't.
The oem rubber part fits pretty well for the Triangle/Wrench it must be said , but you could probably find a webbing/tape with adjustable buckle that will work as well - have a browse around Kathmandu or other outdoor type shops.
