Picture of Cam Hub that can cause Camshaft Failure in 32V engines
Thanks to PorKen for the pic, I cribbed it from another post.
The three-spoke hubs can become cracked over time and are usually not inspected as part of the timing belt replacement. If the hub cracks, the gear can wobble, eventually leading to camshaft failure. There have been multiple reported failures of this kind.
Inspection of this part should be part of the timing belt inspection process, and should also be part of the cam gear replacement process. Per Jim B, they're around $26.00 each. Very cheap insurance.
![](http://forums.rennlist.com/upload/32vcamgearsandhubsv2.jpg)
Archive Gatekeeper
So where do they crack? Here's my driver side hub from July, looks ok (?) And, if you remove them to replace them, I guess you've committed to pulling the valve covers and doing a proper re-timing, since re-indexing the cam gears would be a bit tricky.....
![](https://webfiles.uci.edu/redwards/public/driver%20side%20cam%20hub%207-06.jpg)
Rob Edwards wrote ...
"... And, if you remove them to replace them, I guess you've committed to pulling the valve covers and doing a proper re-timing, since re-indexing the cam gears would be a bit tricky ....."
Why? Assuming the hub can be pulled without rotating the cam (which may be a BIG assumption), mark carefully and don't let anything move. The key on the shaft indexes the hub and the gear is indexed to the original mark or the marks you made before disassembly.
Archive Gatekeeper
Actually, looking at my hubs, it occurs to me that two of the rotor mounting holes aren't in the center of the spokes of the hub- Where do these hubs crack, anyway?
Sterling- that's a cool trick, I like it! My heart just about stopped when the driver's side cams rotated when I loosened the cam gear bolt. Fortunately the old gear didn't rotate on the hub, and the engine was (of course) at 45o BTDC, so I just tightened everything up and just rotated it clockwise back to the 45o mark I made on the gear.
I guess this is all moot anyway, because given the current thread RE: hp improvements with proper timing, I'd like to properly index my cams per the WSM just so I KNOW the timing is right. I managed to hamfist my way thru a TB/WP without breaking anything, and the marks all lined up before and after, but the devil's in the details.
Archive Gatekeeper
Ryan-
A picture's worth 10^3 words:
![](https://webfiles.uci.edu/redwards/public/old%20vs%20new%20cam%20gears%207-2-06.jpg)
yeah its nice and shiny, i mean dull
the cam laying down, to the left, is that the 2nd new one? the sprocket design is different, obviously the dimensions are the same but that sprocket construction is different, i had no idea. That is the new one right?
Archive Gatekeeper
The gear in the background at left is a new steel oil pump gear, it was a WYAIT item. The old one was in pretty good shape, but I put the new one in anyway.
