Where are the ground points on an 1980 model?
I know
but I dont have them with me, can someone tell me where to look, I want to clean ALL the grounds.
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
From the WSM in order:
1 on front lock member, right
2 at rear of wheel arch underneath right rear trim panel
3 on steering console
4 on front lock member, left
5 on upper mounting for fuse/relay board
6 on front wall
6 on front wall
Should be a large ground strap going from the passenger side motor mount area to the body of the car.
Never saw one installed on the driver's side.
To add to John's comment, also check on the passenger side inner fender toward the front - where the headlamp bar goes through the fender. You will find a ground bolt in that area. I can't remember if there is one on the opposite side, but I think there is. There is also one located under the headlight bar just right of center when standing in front of the car. Easy to spot - brown wire(s) bolted onto a small pad on the body.
