G28/10, 11 & 13
4th Gear
What if any are the differences among these three transmissions besides the final drive ratio? How interchangeable are they? Thinking of changing an auto 87 S4 to a manual.
Thanks!
Thanks!
Rest in Peace
Thanks!
Thanks!
Cheers,
How is the 13 stronger than the 12?
The 12 is a S4 Euro trans and 89 only US with a 2.64 vs the 13 is only an 87-88 US trans w/ a 2.20.
Thought Mark used a 57 and Joe F. used the 55.
Rest in Peace
John,
DOH! I will have to ask Mark A to educate the dunce from NorCal, again.
So the 10/11's and the 12/13 differ?
What in the world is a 57?
Or is the 55 LSD and 57 os PSD?
all manual boxes have the same external dimensions; except the later ones which are a couple of mm wider at the half shaft connection.
The late & post 86 boxes have a better and stronger synchro design.
If the box comes complete with rear end then the final drive ratios may vary.
It is rumoured that the GTS boxes are stronger but exactly "how" I do not know
Marton
Marton
To put it simply:
10 and 11 = '85-86, only difference between two is gearing
12 and 13 = '87-89, larger and stronger input shaft bearing and some other more minor changes
55 = GT, stronger again, '89 with LSD and '90-91 with PSD
57 = GTS, see John's list
All are good enough for normal use.
12 = 2.64 and 11/13 = 2.20, LSD optional on all three.
It is strange Porsche didn't change G28/55 to some different number when PSD was added. Casing is different because of it and all.
