It is the terminal that connects to my power outlet in the hatch area. This one is both always on (not accessory power) and directly connected to the battery - even when the battery switch is off (hence the terminal its on). I use this for my mediuum current battery charger - of course with the battery isolated.
Aryan - I'd get the 100A continuous, 1000A instantaneous (10 sec) version.
I also have used Blue Sea Systems HD battery switches - mainly as changeover switches on the positive side. I'm not sure one would fit there - they are quite large... however they are the nicest battery switches I've seen. Great easy changeover action, incredible ratings - looks good (but not as stealthy as the Hellas can be...).
Again unfortunately I don't think one would fit there (and they are about 3-4x the cost).
When I got my GTS it had a battery disconnect at the jump post. The only problem it caused was the poor mounting bracket kept coming loose and then driving over bumps it would turn everything off and on. Quite startiling at night on a deserted highway. Got tired of trying to keep it tightened so just took it off.
A jump-post switch isolates some of the ce panel circuits, but not all. FI, fans on late cars, fuel pumps, abs, alternator, are not isolated by interrupting the circuit at the jump post.
Triggers for the ezk and lh and fuel pump are disconnected when the jump post circuits re opened, so the engine will stop and lights will go out. There's still stuff connected to the battery.
It's been a long time since my engineering study days, but I do recall V=IxR. Does that mean that this switch has too much resistance for a 12V system?
