928 Forum 1978-1995
Sponsored by: 928 Specialists
Be very afraid of your fuel lines
Old 10-04-2006, 08:25 PM
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by Shark Attack
get that damn Chevy out of the pix....
oh, no, cant do it now.
Old 10-04-2006, 09:23 PM
intrepidjohnson
intrepidjohnson's Avatar
After looking at the picture of your front hose I checked mine and it looked o.k. After I pulled it away from the oil filler neck, it was exactly like yours.
Thanks Greg...you may have saved the car and the wife thanks you because you may have saved the house.
Old 10-04-2006, 09:49 PM
Wild Bill
Wild Bill's Avatar
$10.00 ???
Can you explain what exactly you purchased for 10 bucks? The cheapest line is the crossover in front, the one pictured that rubs on the oil filler neck. It is $21.67 from Porsche over the net.
Old 10-05-2006, 02:04 AM
Shane
Sharkaholic
Shane's Avatar
git 'er done...
Thats' all I got to say 'bout that, as I have already had my BBQ shark flank
Old 10-05-2006, 02:50 AM
Tom928
Tom928's Avatar
I've wanted to replace mine on both cars since I was at Shane's place this summer; however, I have learned that the lines that come upto the engine from the back are NLA. To replace them means rebuilding them.
If we are rebuilding, I would ask why we don't use braided steel instead of rubber?
The race guys use it, then it should be safe and reliable. If it is just cost - I would prefer spending extra $$$ on fuel lines that will last longer and be more reliable.
Thoughts?
Old 10-05-2006, 10:04 AM
blown 87
Rest in Peace
blown 87's Avatar
Ya, you cant see it unless you pull it away.
That would be a very bad place to have a fuel leak because of the distributors are a very good source of ignition (Think Jaguar V12 and all of the fire problems they have had, we had one catch on fire in the shop) plus the fuel could spray back on to the ex manafolds.
Old 10-05-2006, 10:58 AM
Brian B
Brian B's Avatar
Has anyone written up a list of lines that need to be replaced? All of us should get rid of the old lines this winter so our sharks (and families) remain safe in the spring!
Brian
79 Euro
Old 10-05-2006, 11:44 AM
blown 87
Rest in Peace
blown 87's Avatar
Brian
79 Euro
I cant help you on a 79, but it should be in the parts manual.
Old 10-05-2006, 11:48 AM
Shane
Sharkaholic
Shane's Avatar
Brian
79 Euro
Give Carl at 928 motorsports a call, he has some nice fuel line kits for the early 928s.
Old 10-05-2006, 11:52 AM
H2
H2's Avatar
As someone mentioned, some hoses are no longer available, apparently. For example, the Horseshoe shaped hose at the back top side of the '85S engine. I don't know how a shop could make this hose with that bend in it? If someone knows who might have this hose, I'm interested. Maybe even a used one?
Harvey
Old 10-05-2006, 12:02 PM
Shane
Sharkaholic
Shane's Avatar
Harvey
That must be a recently NLA part Harvey, because I got one for my 928.
Unless you are talking about the other line coming out of the fuel pressure regulator, the one without fittings attached, there you can get some 8mm high pressure fuel line from Carl at 928 motorsports to do the job. But the horseshoe on between the regulator and damper in the back was availbable when I got them last year.
Old 10-05-2006, 12:11 PM
Koenig928
Koenig928's Avatar
Originally Posted by Wild Bill
$10.00 ???
That twisted "S" hose on the rear (from FPR to bracket) is $8.00 from 928 Intl. - 928 110 359 04
Old 10-05-2006, 06:27 PM
ceedee
ceedee's Avatar
i'll check out my lines this weekend...great tip there
Old 10-05-2006, 06:42 PM
Wild Bill
Wild Bill's Avatar
Okay, that be the cheaper, cheapest one... FOR AN '87! And its just a piece of hose. For an '88 its 10X more and then there are 3 more to buy!
Back at ya!
Old 10-05-2006, 06:57 PM
jpitman2
jpitman2's Avatar
IMHO the hose connecting the two rails at the front should be a rigid metal line. Hoses should not be made to curve at the ferrule, even though it looks gentle. A metal line could be made so as to permanently avoid chafing anywhere, where its more difficult with a hose.
jp 83 Euro S AT 50k
Quick Reply: Be very afraid of your fuel lines
