928 Forum 1978-1995
Sponsored by: 928 Specialists
passenger side seat
Old Sep 28, 2006 | 10:12 PM
shadowknight's Avatar
shadowknight
Default passenger side seat
I am a new owner and im trying to iron out some issues. tonight it's the passenger side electric seat on my 89. The previous owner gave me cable that conncects to the seat. The problem is I dont know where it is supposed to connect to on the other side. the cable is about 24 inches long. Can someone help me.
Old Sep 29, 2006 | 12:26 AM
rmr25's Avatar
rmr25
Tell us which quadrant on either of the two seat switches doesn't work. That may help us help you identify the cable.
Old Sep 29, 2006 | 12:38 AM
rixter's Avatar
rixter
928 OB-Wan
24" long?
most likely this will tie into the main seat harness, should come across from drv side and plug into a block mounted to the chassis
Old Sep 29, 2006 | 10:10 AM
shadowknight
rixter your right, that is exactly the cable I have the question on. So it connects to some point on around the center console is that correct?
Old Sep 29, 2006 | 11:13 AM
Alan's Avatar
Alan
Electron Wrangler
Underneath the seat right in the middle - car side connector is attached to chassis
connector longways is side to side in the car. if you loosen the seat and remove rear bolts you can tip seat forward & install without removing the seat
Alan
By Verdad Gallardo | 2026-04-28 19:00:17
