Early chain tensioner pads
Administrator - "Tyson"
Originally Posted by Flormat
What are all of the '85 & '86 owners doing?
Inventor
I was reading through the 86 service bulletin last night, and it shows an updated chain tensioner (different valve plate), but it must not be the same as the 87 tensioner.
Inventor
Here is the picture of the old style tensioner
and the new style pad to fit on the S4 and later cars
as well as 944S. The new style pad slides on the
piston block from the side where as the old pad is
screwed on from under the pitston block. The block on
top of the piston is a different thickness so the new
style pad will not fit on the old style tensioner.
Inventor
I'd have to see it all for myself, but it looks like you could use a machined block of steel/aluminum to bolt onto the tensioner, which the S4 pad could then slide on to?
What are the measurements of the two pads?
I just heard this morning from a person who knows about 928 rebuilds and he says that they original tensioner should not be reused.... the superceded parts should be bought i.e the whole tensioner and oil line
In an earleir thread on the subject someone way saying that some of the thread holes for the oiline did not match up when he tried to supercede... I will look for the thread.
LO
LO
I just compared the old 928S tensioner with the one I replaced in my 944S a year ago and the spring tension on the S4 and 944S tensioner is about twice that of the old 928S tensioner. Are the newer style S4 and 944S tensioners pretty durable? I'm wondering about just using my old 944S tensioner with the new pad? I have access to another used 944S tensioner for the other bank on the 928. Or is that a bad idea... Any thoughts?
Like I said before - the only reason I know of for changing the entire tensioner on a 944S / 928S4 is due to the lower pad not being available. So if you found a source for the both pads:
1. Sounds like a plan
2. Care to share the source?
No, I have not found a source. But my parts guy wants me to bring everything I have in see what he can do. Don't know what he has in mind but I'll find out and let you all know.
LO, I posted the thread about the oil line not fitting the updated tensioner! Im still waiting for oil line and its been over 6 weeks back ordered from Germany. As you can see in this picture the bolts for the J- tube superceded!
Dan
Dan
Originally Posted by Hacker-Pschorr
Flormat,
Some follow that theory - I obey the "$300 is better than new cams, head & valve's" theory
The pads are plastic, over time they become hard and brittle - sure the top one shows the most wear, I will not trust a high mileage lower pad either.
The upper pad broke apart on my 944S (destroying my cams in the process). When we took apart the head, the lower pad snapped with very little force it was so brittle. At the time I could not find any supplier offering the lower pad so I replaced everything. The 944S and 928S4 use the exact same tensioner & chain.
Dan,
Who sells this set?
Dan,
Who sells this set?
Harvey
There is a reason why the pads are not easy to find - Porsche does not even list the pads or the tensioner as a wear item. I tried to get a dealership to replace my tensioner years ago, I was told it's not a wear item. 4 months later it blew. Most 32V 928 owners do nothing with the tensioner.
Harvey
