Fix the little things - PERFORMANCE MODS
#76
928 Collector
Glenn I don't know, possibly. It's about turbulence not flow. Brett Hi Buddy
.... walk up to a chain link fence. Nkay? Now look at what's on the other side of it ... see it? OK now put your cheek against the fence and look at a 5 degree angle almost toward the other end of the fence. Still see what's on the other side?
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#78
1 Post
The point is was trying to make lol....was if the mesh in the K&N can affect the airflow...what about the much smaller mesh in the MAF screens ???
Surely they would affect it even more....as there are 2 of them and smaller mesh ...
All the best Brett
PORSCHE 928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES ,RMB ,PROMAX CHIPS, KICKDOWN SWITCH.K&N.NITROUS KIT 150 HP.
PCGB UK 928 FORUM MODERATOR - Email managingdirector@pchealthcare.co.uk
#79
928 Collector
Well we don't know but my theory is that the air hits the MAF screens straight on. But they hit the KN screens at a very sharp angle, thereby reducing the path to a crooked one, creating turbulence..
#80
Inventor
Originally Posted by Loaded
Has anybody ever tried slapping a HOLLEY double pumper on one?
![](https://members.rennlist.com/porken/Project928CarbVsFI.jpg)
16V US engines have a vestigal cast hole in the heads (square hole between center intake ports) which was the exhaust crossover for the carb'ed intake manifold!
#81
Received 1,634 Likes
Originally Posted by Normy
Worf, you are simply getting the Bosch EZK...
#83
Dave.............just read your long thread from a couple of years ago re. your 'gutless GT'. Did you derive that the 'hall sensor' was the issue because you had performed all other tasks? I don't see what pointed you in that direction?
Just had the car out...........no chirp from full throttle in 1st or 1st to 2nd at WOT.
#84
the enclosed graph is supposed to show the performance effect of MAF ageing. It is not especially accurate as MAF ageing is a function of switch on/switch offs
Marton
Marton
#85
The original purpose of the thread was to poll for any other cases where known HS failure resulted in a similar or identical failure mode. When I received a second confirmation from a trusted source (Scott) and given what I already knew about what I had personally R&R'd on the car, I decided that the HS was the most likely candidate. However, the thread, after post #7 provides a lot of anecdotes on other failure modes that are relevant to this thread's subject.
From the final few pages you'll see that the HS was the primary culprit for my "Powerless GT" but that a dyno test confirmed that my '89 was still down by 25 to 30 hp as compared to other '89 GTs. (IMO, 295 to 300 rwhp is the benchmark for a perfectly running _stock_ (except for RMB) '89 GT.) I have not yet done anything to 'find' that missing hp because 1) I decided that other ailments of the '89 and the suspension upgrade had higher priority at that time and 2) all signs pointed to that missing 30 hp being deeper in the motor - as in head damage, or low compression. Having been in and out of the 'shallow' parts of that motor three times in the previous year I was ready for something else anyway. My next steps on the '89 are to do a leak-down test and possible a compression test.
My diagnosis of the HS - aided by John Speake and Scott - was as "easy" as described above because I had an near-absolute baseline (except for leak down / compression numbers) for the maintenance of the motor as I had over the previous year fixed or tested-good all the other possible culprits (IIRC. Careful reading of the thread might find one I missed.) But, the thread shows just how elusive a HS sensor failure can be without such a known baseline. Flappy? LH Brain? Fuel pressure? Vacuum? False air? Wiring? Injectors? Plugs? Wires? Coils? MAS? Cats? Exhaust?
Since that thread I have found yet another problem with the '89: The Hammer diagnostic port is as dead as a door nail. The Hammer, PWIS, and PWIS II (The latter two being Porsche's newest replacements for the Hammer IIRC.) cannot find any of the ECUs or test any of the actuators. So, the Hammer - like on an '87 or '88 - would not have helped find this failure.
So, we wind up back at *my* methodology for the HS: Replace it when you have easy access to it. Else, and especially if you do not have a maintenance baseline, or a diag port and easy access to a Hammer, when it fails it becomes a real hail-puller-outer of a problem.
#86
I know I've only got L-jet, but I noticed a huge improvement when I changed my AFM. I had a flat spot at about 2000RPM that went away instantly. I had read that the sweep arm contact of the AFM can cause wear patterns that interfere with predictable response. After checking my other sensors and a new O2 sensor, I took a stab at it and had a good result. Got a rebuilt unit from 928 Specialists; thanks.
#87
Originally Posted by John Speake
Hello Greg,
Perhaps I didn't explain very well.....
The MAF hot wire takes a sample of the total airflow into the engine and converrts that into a voltage. That voltage (or more correctly a modified and processed version of it) coresponds to a "load" value on the main fuel map. The other axis of the map is rpm. The map tells the LH how long to open the injectors for (they are all fired simmultaneously).
If you changed the airflow into the MAF, then it may indicate a different voltage at a particular throttle opening than it did before. So this will mess up the fuelling to a greater or lesser extent. A small change may not cause a problem at cruise with a cat equipped car running closed O2 loop, but when you're at WOT, then it's open loop time, and an accurate airflow reading into the engine is critical.
In a perfect world the airflow into the MAF would be laminar, and then it would be easy to change things without upsetting something. But life ain't like that...
The implication of a small drop in power/torque at WOT with a K&N is that it is the result of a weaker mixture than stock. I wonder if anyone has checked this ? Louie ?
Hope this helps.....
The one design flaw in the 928 intake system is that the air enters the ends of the air filter housing and has to go through the filter, travel to the center, make an abrupt 90 deg turn and immediately enter the MAF. It doesn't really like to do this and much of it travels horizontally across the top of the filter and goes pretty much straight down near the MAF opening. Notice how it's the center of the filter that gets dirty first, not the ends by the inlets. The MAF likes undisturbed moving air to produce an accurate measurement. The MAF doesn't particularly care which way the air flows across the wire. Downward, upward, sideways, will cool the wire and produce an output. It's only the air mass that gets into the combustion chamber that counts in an engine. When turbulant air goes through the MAF, it will produce an unpredicatable, erroneous, and widely variable output. How will the LH process the variable, fluttering, signal? Who knows? I'm sure it has some electronic filtering on the input to average out the variations. The electronic filter would be optimised for a stock filter, not a K&N. I'm pretty sure the LH mostly is confused by the variable air flow and outputs an unstable injector pulse width. Whether it ends up being rich or lean is anyones guess, and is probably a little of both. Quite a few things in the 928 intake contribute to turbulent air entering the MAF. The close proximity of the MAF to the air box and 90 deg turn for some of the air to enter is one. The close proximity to the air filter element is another. The air source at the ends of the box doesn't help either. Anything you can do to get as undisturbed air as possible into the MAF will help. The coarseness of the K&N pleats contributes to turbulent air entering the MAF. Remember that the air is somewhat going through the filter element sideways other than in a spot directly over the MAF. Like H said, look through a very open chain link fence sideways as an example. I've done some experiments with air flow in the airbox. I tested on my GT, Heinrichs S4, and a few others. Mike Schmidt made a nice example for his S4. I made a raised section around the MAF opening with a larger radius. Like a toilet seat. I called it the Einholer.
Now, could you tune with a K&N to get good power and then show less with a stock filter? Probably. You could cram a potato up the exhaust and tune for that too.
There is a place for filters like the K&N. Extreme performance where you don't want the filter to clog with dust. Vehicles with inadequate stock filter capacity systems. Installations where there is some distance between the filter and the MAF should work ok. None of this applies to normal street driven 928s.
Here is another set of dyno runs I did comparing the stock filter with the K&N. I believe this is when I was testing the Einholer air box MAF hole. I was still trying to get decent test results from using a K&N filter since at the time I still believed the hype. The air filter would then be about 5/8" closer to the bottom of the air box around the entrance to the MAF than a stock air box. It exaggerates the effect of the turbulance near the filter and MAF inlet. Both show about the same numbers. Which would you rather drive?
https://rennlist.com/forums/attachme...d=141154&stc=1
#88
The MAF hot wire takes a sample of the total airflow into the engine and converts that into a voltage...
So, if that is true then the measured mass of air should not be a direct function of the absolute rotation of the throttle plate. It would however be an indirect function of the mass and density assuming that nothing else is different.
(Note the question marks above John
If more air flows into the engine at a particular RPM and throttle position, then that would move the LH operating point on the map up to a higher value, and would result in more fuel being added.....
Like I said, this is not a perfect world... here's are a couple of K&N theories.
1) The >87 cars run quite rich at the WOT top end - does even more fuel, due to less
restriction make it even richer, lowering power ?
#89
Louie beat me to the punch and has the data to prove it!
#90
Owns the Streets
Needs Camber
Needs Camber
In a previous discussion about the damn K&N filter with Dave C., it was noted that the K&N is a flat filter whereas the stock paper element is a raised filter. (We were trying to decipher whether the arrow points up or down on the paper filter)
The conclusion was to install the paper element with it being raised from the MAF opening. Much like a mini version of the Einholer.
It's also disconcerting to look through my ex-K&N at a bright light source and be able to see through the filter. Can't do that with the paper element filter.
Ernest (NYC)
K&N free for over 2 months.
Originally Posted by Louie928
[snip]I tested on my GT, Heinrichs S4, and a few others. Mike Schmidt made a nice example for his S4. I made a raised section around the MAF opening with a larger radius. Like a toilet seat. I called it the Einholer.
It looks similar to the air box bottom on an '85. I also made a spacer around the bottom section of the air box to raise the air filter element to give more space between the air filter and air box bottom. The Einholer opening netted about 5-6 lb ft of torque below 4500 and the raised air filter helped above 4500 to give 5 -6 hp on top. [/snip]
Ernest (NYC)
