to the bat computer I go- speedometer
Speedo, someone have a brief rundown of wiring. Speedometer and fuel gauge no work before cluster rebuild, now everything works but the speedo. the odometer does not work either. please daddy dont make me take out the cluster again... it went back in so nice this last time
Official Rennlist
Borat Impersonator
Borat Impersonator
for the speedo check the connector in the spare tire compartment. check the wiring diagrams and on of those wires is from the sensor from the speedometer. a lot of times when the speedometer doesnt work or works sometimes it is this connector.
Originally Posted by Shark Attack
where is the sending unit?
The connector that feeds this signal to the speedometer is the closest one toward the steering wheel on the left lower instrument panel plug.
This is where I am currently. I need to check continuity from the rear of the car to the connector.
I've had the speedometer rebuilt and tested in the instrument panel, so I know everything is good there. The problem is somewere leading to the panel - wiring between the back and the plug - bad sending unit in the transmission - I hope it is just the sending unit, but I believe mine is okay, it passed the resistance check.
Good luck and let me know how it turns out.
Rod
Rod
Ok just to clearify, this is the plug located almost under the speedo and is the contact closest to the steering column... yes im dense
I'm equally dense, everything is a mystery the first (or seocnd) time.
Rod
Hey Rod,
Your info helped fix this issue. I had super glue goo on the connection under the dash on that connector and pin you told me about..... now all my (knock Knock) instruments work!
