S4 temperature regulator housing removal
Hi, my '90 S4 auto is leaking water from where the regulator housing joins with the ?water pump?. I believe that there is a 53 by 7 o-ring in that junction. Can anyone advise what needs to removed to replace this o-ring - it looks like the oil filler, and hence inlet manifold, may need to be removed, also some ?fuel? lines that run across the front of the housing. Thanks, Myles
928 Collector
Probably, they aren't that expensive. It may not be necessary to do that Myles. Someone asked this very question very recently. Remove the thermostat housing elbow before you pull the bridge, it will give you more room...
