A New Monster In the PNW, Congrats Louie!
#31
Originally Posted by pmotts
When do you plan on supercharging it?
Your roads are going to seem much smaller than they used to
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#32
Originally Posted by marc@DEVEK
Louis - You are very welcome.......10 years of carefully planned R&D does pay off....glad you are pleased with the result.
Marc,
One of the 1st things Louie mentioned last night was Marc really know's his ****... or something like that.
#34
Marc,
One of the 1st things Louie mentioned last night was Marc really know's his ****... or something like that.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
#35
I'm gobsmacked! When I saw the dyno graphs the coffee I was drinking just about went down my pants. That's not a torque curve, its more like a torque "line". ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Or you could unreasonably take the highest number, apply a non-standard TT/TS/CS semi-variable BS factor derived from the old "Bench-Racing" scale with a "mine-is-bigger than yours" exponent (you must of course use a reduced/increased (?) gear ratio multiplier with the exponent!) and probably get an easy power number of say... 694. Oh what the hell. Why be so conservative? let's just round that baby up to ...700.
Any way you want to figure it, doesn't make that much difference. Your long hours and diligence are paying off big time!
Glenn
Originally Posted by Louie928
Conclusion is that you could reasonably say the power was 553 to 598 and have some valid basis for the number.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Glenn
#36
Originally Posted by SwayBar
Oh my gosh is that beautiful, especially the air/fuel!!!
I figured out a method to zero in on the A/F ratio you want from the A/F ratio you have so it's not too difficult. Just takes time and being patient enough to have close to the same conditions for each run. Usually 2 or 3 runs was enough for each throttle position setting. However, that could take 2 hours.
#38
Glenn
Glenn
Is gobsmacked a good thing? You are right about the long hours. Maybe even due diligence. I've often thought that what I was laboring over was to produce a result about like a higher boost TS 5L at about 2 or 3 times the cost. Of course when I started this, TS 928s wern't around, and I wanted simplicity and lots of cubes.
#39
Originally Posted by Scott M.
Louie;
What fuel management software/piggyback are you using? I believe you mentioned to me that it wasn't an SMT-6.
I'm using a stand alone ECU. The brand is DTA, and model is P8 Pro. http://www.dtafast.co.uk/
The software is vintage Windows 3.0, controlled by part mouse and part function keys complete with a few undocumented "features". Obviously poorly imported from a DOS program. The automatic fuel correction map they tout I find to be not reliably usable. The basic hardware/firmware part does have many features, many of which I'll not need such as traction control, launch control, turbo anti lag, and more. Everything I needed worked as advertised. I grew to really like it and got fairly proficient at tuning with it. I went to the standalone ECU because I do not use the MAF. I also wanted to eliminate the distributors and thought sequential injection with timing of the injection pulse would be an advantage. Individual cylinder fuel trimming is available for fine tuning when I get the EGT system working. I'm a DTA dealer so maybe a bit biased, but as you can see, no salesperson.
#40
Excellent work Louie!!!
MK wrote:
I'll remember that
MK wrote:
by the way, if that was in a race car, you could shift at 4000rpm and have a car as fast as the holbert car. (average 320rwhp gear to gear!)
#41
That is one beautiful piece of work. I am constantly amazed at what can be done with these cars.
Louie, that is one awesome ride you have there!
Jim
Jim
#42
One thing about Professor Ott, he thinks carefully each step of the way. And he doesn't trip very often, if ever. I'd trust him implicitly with any thing I own.
Harvey
Harvey
#43
Originally Posted by mark kibort
supercharged??? you were referencing "pulleys"
If its the tomas /Ott design, do you have to cut holes in the hood for the intake?
extremely impressive.
Mk
Mk
Not supercharged. That was an attempt at a joke because what I got is what I got. I have no pulleys to change and get more.
The intakes will fit under the hood just barely. I think the stacks are too short to take full advantage of the resonance tuning effect to enhance the normal torque peak around 4500 rpm. You can hear it "tune up" starting at around 5000-5500 and the sound extends to where I shut off at 6600. They do, however, extend the torque range at the top end which is what I wanted. I don't know where the top end of the tuning effect would be. You could probably run it out to 7200 before the hp peak fell much. That won't happen on this engine. The piston speed is very high at 6600. If the high rpm oiling issue is solved for the 5.0L engine, I think this would make a super high rev setup. My next project. The air horns were 2" long above the TBs. Total intake runner length of about 10" I tried a set of air horns 3" long with no discernable difference in the torque curve. It may take horns 6" to 7" above the TBs to see an effect down lower. Longer horns should increase the torque more in the middle, but I didn't want more there so this is just fine.
#44
Jim
Jim
