Well if the interior lights work in all modes then the motor should at least run when you pull the switch. Test the switch by shorting the connection on the switch with a screwdriver. Test that the red wire to the switch is @ constant 12V. On the motor end test that the Brown/White wire is @ ground (~0 ohms) when a door is open (you will probably need to pierce the insulation with a pin for this?
It could just be that the motor is stalled due to an alignment issue. unbolt the 2 retaining bolts on the central strut for the motor and move it up/down a little. You may find pushing on the actuating lever a little (the exposed portion driving the release arm) will help free things up. If all else fails remove the arm altogether and/or remove the whole motor assembly.
If it still doesn't run - disassemble everything and check for damage and test the motor stand alone...
Got the arm un jammed, seemed to be working again. Wouldn't open hatch so went through adjustment procedure, motor stops working again, look for other jam, unhook arm all together, no work. How test the motor stand alone?? I unhooked it from everything, and no work, does it need chassis ground? When I pull the switch I hear a click.
